PS HX 500 Turntable
Brained1
PS HX 500 Turntable
The most minor niggle: Grips on the dust cover, left and right would make dropping the lid less likely.
EdwinaU
Moderator
Hi there,
Thanks for posting your suggestions for the PS HX500, your feedback is always welcome.
Best wishes,
Ed
EdwinaU
Moderator
Hi there,
Best wishes,
Ed
