Sony Reader prs-t1 doesn't support 802.1x EAP secured wireless connections
trozby
Whenever I attempt to connect to a wireless network that uses 802.1x EAP, I am told that this protocol is not supported.
This seems quite bizarre to me, as I have other android devices which have no problems whatsoever connecting to the same networks.
Can this be enabled in a future update?
It is quite frustrating as I am part of an institution which only provides a network using this security protocol.
0 REPLIES 0
