Sony software for srf raw files
profile.country.GR.title
user828
Hello,
I recently acquired a Sony F828 in mint condition, in order to experiment first-hand with its unique 4-color sensor. However, the current software available from Sony (I also use a Sony A7 body) does not support the old .srf raw files of the F828.
The Adobe products allow proccesing of these files but the colors and file integrity are way off the results from the .tif files with as muted settings as possible.
Older versions of Image Data Converter support .srf files but Sony does not offer downloads of that software any more. The original CD is lost.
Any suggestions would be welcome. Thank you.
Anonymous
@user828 it's quit an old model not even supported on Imaging Edge Desktop I don't that would be possible
