Remote for HDR XR160E
lancsb
What remote control is available to work with my Sony HDR XR160E camcorder
Mick2011
hi lancsb, welcome to the Sony Forums :slight_smile:
There's no wireless remote function, but your camera can use the (corded) RM-AV2 controller:
http://www.sony.co.uk/product/cac-other-accessories/rm-av2#/Overview
Mick
5 REPLIES 5
lancsb
Hi Mick
Thanks for that information, I was hoping that would be the case. I will obtain one and hope I don't keep tripping over the cable!!!
lancsb
Mick2011
You're welcome :cool:
It's not a long cable (1.5m) designed more for attatching to tripod grips, etc. Hope it does the job!
Mick
Mick2011
Mick
lancsb
It would be better if I could find an extension lead for it? Is there likely to be anything available. Calling on your good advise again!!!
lancsb
Mick2011
Going to be a bit tough to find; I know Sony don't make one. It's a reasonably common jack, though.
You'll see it described as an AV/R or A/V-R plug, sometimes colloquially as a '10-pin D' plug due to its shape and terminals; look above the HDMI jack on your camera. The hard part will be finding a male-to-female extender & a quick Google didn't bring anything up :thinking:
Another solution might be to get a LANC adaptor cable (AV-R to LANC) which may also extend your remote control options, as LANC is a very common video remote interface and there are a lot of LANC controllers around. The best thing in this case would be to take the camera to a quality (ideally professional) camera store and try out some basic LANC controllers in conjunction with an adaptor cable and see what works.
Mick
