volume of Head Phone very low
Sandy915
I installed VLC player of anorid on my phone(Xperia c) while waching few of the videos I am not able to hear the sound as it is very low while some work very fine. Is it problme with headphones or with the videos. Solution requested.
profile.country.RO.title
_alexdon_
Clear data for sound enhancements under settings-apps-all and restart.
alexdon
4 REPLIES 4
_alexdon_
Have you tried to raise the volume for media?
alexdon
Sandy915
Yes, i did and I could not hear even when the voloume was on full high.
Please advice.
_alexdon_
alexdon
Anup1234
Use MX Player.And try to increase the volume,
if you found its the same as provided by VLC,Open media throgh mx player, then click nusic button on the right top corner,
check software encoder,
Done!!
