X94J Built in mic
D-Law81
X94J Built in mic
Hello all having a issue with built-in mic on my Sony X94J 65" I have flicked the switch on the TV but no light come on and when talk (OK google) no response, remote works but not TV. Any one know why. I would have helped if TV came with a full Manuel.
Tags (1)
D-Law81
Hi did a factory reset with TV mic switche on, and this has fixed the issue and at the moment the freezing picture on the Bravia Core seems to be fixed too. Thanks for all your help. 😊 Let's hope all stay good. Love the TV.
4 REPLIES 4
LightFoot
Specialist
Hi @D-Law81
Looking at your reference manual on Page 4 [10]. It appears that you may have to enable it as well as switching it on. No doubt that Sony need to cover themselves by making you responsible for an open Mic on your TV.
https://www.sony.com/electronics/support/res/manuals/5025/c8e98cffe14c82ce7ca990f10ce343ba/50253041M...
Please let us know how you get on, the XR-55X94J is on my wish list.
D-Law81
May have missed, will look again. But couldn't find enable in menu - switch is on will have a look.. Will let you know. 😊
D-Law81
Joe_Dohn
Specialist
Glad to hear it was solved for you, been hearing nothing but good news about this TV and it's exciting.
Thanks a lot for sharing the update and marking the solution, much appreciated!
- JD
