Voice activation not working,Bluetooth issue.
Pigmalism
My voice activation is not working as there is an error with my Bluetooth.
Even though I turn it on it turns itself back off so it seems.
Any ideas ?
5 REPLIES 5
rooobb
Did you try a simple restarting of the tv? Or in case it does not solve a full factory reset?
Remember to state always the full tv model in any case
Pigmalism
YesI have tried that to no avail.
Pigmalism
It’s the KD55XE8396
rooobb
Have you tried both? If yes there could be some problem with th wifi/bluetooth board...
Pigmalism
Yes tried both.
Ill get onto support then.
Thanks.
