My voice activation is not working as there is an error with my Bluetooth.
Even though I turn it on it turns itself back off so it seems.
Any ideas ?
Did you try a simple restarting of the tv? Or in case it does not solve a full factory reset?
Remember to state always the full tv model in any case
YesI have tried that to no avail.
It’s the KD55XE8396
Yes tried both.
Ill get onto support then.
Thanks.
