Sony KDL-43w755c
I have a kdl-43w755c andriod tv which i got back in 2016 and it stopped working 1 year later with 5x red blinking light whislt I was using the tv (it just turned off). Now im looking to fix it but need some help. From what i have researched i think it might be a T-Con Board fault but not 100% sure if anyone could give any help that would be great.
Thanks Again to anyone who helps
Well, that's really hard to say without measurement/analytics.
5 red flashes usually mean a  bad lcd panel connection or internal lcd short
So it could also be related to the panel itself. However, could be the T-Con board as well.
Peter
