Hiya, does anyone know whether this wall mount will be compatible with the AF9 55" OLED? I already have a wallmount setup and don't really want to buy a new one. Thanks
https://www.theplasmacentre.com/wall-brackets/tv-wall-brackets/um105l-super-thin.html
The wall mount shown in the link provided is not exactly the same one as mine but looks very similar, the one I have you can mount TV's up to 60"
Hi sabhatt69,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Hi Sabhatt69,
I believe you'll need a VESA adaptor to connect it to this one. The VESA dimensions of the TV is 40.0x 20.0 cm ( W x H ) .
I checked the Sony website and found a fully compatible wall mount: SU-WL450. I'd say it's safer to use this one.
Cheers,
The_Black_Rose
