Picture settings changing on its own between SDR and HDR for 55XE9005
fredwerk
So here is my problem with my Sony Bravia 55XE9005 - I have the SDR mode set with preset Standard and rest of settings set as I want them. Then when I view something in HDR, I set the preset Vivid and again tweak the rest of the settings.
The problem is when I return to SDR from HDR, my SDR settings have changed including the preset remaining on Vivid.
Is this a bug? What can I do so I don't have to, all the time, make sure presets and settings correct?
Many thanks,
3 REPLIES 3
Pascale_F
Moderator
Hi fredwerk,
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
AstroSmurf
It's how the tv works, not ideal really.
Win_88
Specialist
Hi Fred,
Is it the same input that you use to get HDR and SDR at different times or are they multiple inputs?
Win_88
