Hi all, I wanted to set reminder from epg guide list in my TV yesterday but TV switched on after 15 minutes but TV should have switched on 2 hours later.Recording is working ok, TV is waiting for setting time and starting recording on time. TV was Off that time.
I am using CAM CI+ card inserted into ci slot to watch paid sat channels
Twin sat tuner is not working because when TV is recording one channel I can not watch second channel I have black screen.
I have exactly the same problem on my x85 tv, using the terrestrial tuner input. Recording an encrypted channel at the same time as viewing another encrypted channel will cause black screen. Works when second channel is a non-encrypted channel.
HI there
Since the new firmware update a couple of weeks ago, has this fixed your problem?
