firmware upgrade to v2.0 on slt-a55v
i.alder
hi
i am considering upgrading the firmware on my slt-a55v to version 2.0.
i notice the upgrade program is the same for the a55 and the a55v.
does the program detect the model and install the correct firmware?
just asking as i do not want to brick my a55v.
and also, is the upgrade worthwhile for new features or bug fixes??
thanks for any reply.
Mick2011
Hi, welcome to the Sony Forums :slight_smile:
The a55v tech support page has the official update and can be relied upon to get you to v2.0 :cool:
Improvements, from the update page:
  • Addition of the [Picture Effect] function.
  • Enable to assign often-used features to the D-RANGE button for customization.
  • Addition of a new mode to turn off display parameters.
  • Improved operability of the Menu.
  • High-Speed Synchronization via wireless lighting operation of the applicable external flash.
  • Addition of Digital level gauge when using the optional external monitor such asthe Clip-on LCD Monitor, the CLM-V55.
Mick
Mick2011
Mick
