Where do I insert an aux cable?!
Alishia
Hi
I have Xperia 5 J8210 and I want to connect aux cable to my speakers but there is no cable port? How do I work the speakers without one?
2 REPLIES 2
profile.country.AT.title
skycamefalling
There should be an USB-to-aux adapter in the box that you can use.
Martin1
Enthusiast
Hi @Alishia and welcome to the support forum!
As @skycamefalling said, there should be a USB-C to 3,5mm-adaptor which you should be able to connect a AUX cable to in order to play media through your speakers.
I hope that helped a little bit! Let us know if you have any other questions.
