Xperia 10 III - Ringtone and notification tone problem
profile.country.SK.title
LG-studio
Whenever someones is calling me, the phone is simultaneously playing the actual call ringtone and the notification tone. I have tried everything. Factory reset, new update, but cannot resolve the problem. It is not a huge deal, but annoying. Does anybody else have this problem.
6 REPLIES 6
Piscie
It's pretty much annoying! I guess it's a software glitch. I'd recommend trying a software repair via Xperia companion from here, it should sort this out.
LG-studio
Did that, but still the same. It is an interesting bug for sure.
Tags (1)
Piscie
Well, it might be not relatable, but have you tried different SIM card? Also, does that happen with all the numbers or specific number only?
profile.country.RO.title
AlexandruRai
This bug was reported by me and my friends for XA2 models for almost 3 years (android 9 upgrades) L3, L4 the same issues, more than that, some app (WhatsApp/Viber-like) were blocking sound notifications to be heard while receiving calls and still nothing solved 100% for those devices too! Most of those devices were resealed...
Sad is that someone like you share so late the issues! Many don't have idea and many simply switch to Crapsung or some Chinese crap, but surely someone screws big time for Sony's development, and it's not funny at all regarding what happened to LG...
Ps: After upgrading to Android 9, XA2 family, had in their camera EXIF writing the Chinese ZTE modules. Yes, ZTE in their api2 EXIF data!! Nothing solved you can check for yourself if still using one, I have proof!! So who is caring about Xperia now surely must be ONLY SONY, otherwise it's nasty...
AlexandruRai
Anonymous
Hi @LG-studio,
If you're still facing the same issue after the software repair, I recommend that you get in touch with Sony support to investigate further in this issue.
