Xperia 1 sd card unavailable problem
Kevchan10
When start the camera app,  it will show up"sdcard unavailable" message. What is the problem came from?  My sdcard is new,  the phone must be no problem,  because I have another xperia 1 device with another new 512gb samsung evo sdcard,  also have same problem.  On facebook some user also disscussing about that issue,  please help
20 REPLIES 20
Kevchan10
How to do it? Put a green photo into the dcmi folder?
j2ee
 I just have the same problem with my xz2p with latest patch. My xz2p is pretty new, only used around 4 months. No problem at all before taking photo today.
kelvinyang
_CH
I'm experiencing the same problem too. It is pretty annoying.
Also, the workaround provided by the above link, does not work.
Lord_viridis
Have these SD cards been size verified using H2testW on pc?
That's the first place to check SD cards with unavailable or read issues.
_CH
The message of 'SD Card Unavailable' will only flash for a split second when invoke the default camera app using the shutter button.
_CH
Hi all
any other possible way to try?
many thanks.
LeoHK
The problem still occur even I upgrade to Android 10
Kevchan10
Thats sony camera app problem.  Test another camera app can save photo to sdcard., no problem at all
