Hi, guys,
I don't know if the problem is already rewiwed somewhere, but... Since tonight my camera (on Xperia 1) is making a funny clicking sound whenever I open an app they uses the back camera or swith to it from the front camera. I observed that the top lense is moving slightly upwards whenever the back camera is on use. When not it goes slightly downwards.
Is that normal or should I consult the retailer concerning repair or return?
Image quality is otherwise not affected.
Sound is normal.
There is another topic somewhere here were it is discussed.
If you say so... Although... Why didn't I hear it before???
