My Xperia Z5 Premium won't turn on.
I've pressed and held the power button. Didn't work. The hard reset is not working. I tried pressing the off button near the SIM and tried turning it on again. Didn't work.
But when i hook onto the my computer or charge, charging normally (%100 now) first red light .. after turning green light
PC Companion isn't recognizing it either.
Please help!
What if you remove both the SIM and SD cards > connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2-3 hours > try to turn it back on.
Hi @Confu,
Welcome to the community. I am sorry to hear this.
Please do try the steps uliwooly suggested as that can resolve the issue a lot of the time. If that does not work, please try a software repair using Xperia Companion.
