z2 very slow charging after upgrading to lollipop ?
m3lm
Please help me
After i upgraded my mobile from kitkat to lollipop android i charged my mobile .. from 5% to 70 % it took over 6 hours !!!!
Before updating the maximum time was 3hours from 1to 100%
P.S : the same cable and chager is present .. Nothing new used !!!
please explain what happened after this update ??
18 REPLIES 18
Thommo
Not sure what we can do to help but maybe it's just that you have upgraded and it may take time to settle down - You could try performing a system repair
Performing a system repair using PC Companion will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
m3lm
Already did that ..
i tried to recharge the mobile when its powered off
At 99% its come green flashing and the electricity sign is flashing appearing and disappearing !
Before i update from Kitkat i was able to use my mobile while im recharging it , but now when i use it some times a message appears tell me something like " the power im consuming is more than the mobile is getting from recharging " and it said leave ur mobile to be recharged .
Also im getting "No service" message on lock screen altough i have a mobile data connection !
My mobile became strange ..please do something i started to hate my mobile 😞
That's normal if you are using the phone while playing games or multitasking.
Are you charging the phone through a Sony's wall charger? Dock? or Computer?
@m3lm
m3lm
Im using a wall charger
And nothing new ive used .. the same cable & charger
i know that's normal .. but im not multitasking only chatting on messenger
Before i update i was doing the same activity and the battery was recharging and it's percentage is going up .. now it's going down
Plus the "no service" message appears on lock screen although i have mobile data active with an internet connection !
I think we may need an update to fix all of this bugs or if there are different ways to solve . Please help me .
You could repair the phone, if that doesn't work then you have to go to settings > power settings > battery > check what's using up your battery
Cig4r
Same happening with my xperia z2 Please solve this ASAP as its very problematic.
Southernman
Yes i have the same issue after install of Lollipop yesterday. First Charge has problems with a maximum of 83% Charge only.
I note same issues reported on XDA forum as well.   The charging side of the Z2 seems to be a real weaknes with Sony kit?!
Come on Sony lift your game here please...
riacris017
I have the same problem for my z2. When I updated to lollipop, it only charges upto 86%. I can't charge my phone upto 100%. I use the same sony wall charger i use before.
TudorM
Same problem after update to Lollipop... very and annoying slow charge. What can be done, Sony?!?!?!? Can I downgrade to 4.4.4 ?
