Xperia Z5 Premium won't turn on and 3 blinking light when plugged in
Patch0603
Hey, my "waterproof" z5 Premium won't turn on after being submerged, and when I plug it in all just have a 3 blinking red led light, nothing on the screen, any ideas????
thanks
4 REPLIES 4
Patch0603
Any Sony tech boffins have any ideas?
Jake-SonyXperia
Champion
Hi @Patch0603,
Welcome to the community,
I am sorry to hear about the issues you have had Slightly_frowning_Face
The first step I suggest would be to hold down the Power Button and the Volume + key together for around 10 seconds. This should restart the handset and may allow you to boot the device up.
However as this happened directly after being submerged, you may need to contact Customer Care within your region, as the device may need to be examined by a service agent.
Use my signature below to find contact details for your region.
I am sorry for any inconvenience.
dhodz
i have xperia z5 premium dual, it flashing red to green and it wont start.. i tried xperia companion software repair but  still the same.
@dhodz
I'm sorry to hear that, but you have to contact your Local support to get it inspected and/or repaired.
