I updated my phone to latest software in the of update after I charged the phone to full it shows me in battery setting that it last for 32hrs they day after it after a full charging it shows me that it will last 23hrs and the day after it it shows me that it will last 20 hrs why is that why it shorted the time of battery will lasting and I don't use any stamina mode please answer quickly
the time given is only an ESTIMATION and not the actual time left in a single charge, it will change according to the user actions, say for example if you don't touch your phone for an hour or so at 50% battery charge , it might say it will last up to 24 hours , but given at the same charge and you used the device for heavy browsing or playing music it will adjust accordingly and estimates at a few hours given the continued used.
I'm sorry but what a UT?
lots of people are complaining regarding this matter, I dont have the answer and if they are working on it. you can try to use the search bar above to read about those problems and possible workarounds.
but here's a test you can do if the microphone picks up your voice well.
go to settings>support>tools>diagnostics>microphone, can you hear your voice well?
also you can try to adjust mic sensitivity
settings>sound and notification>accessory settings>mic
I dont know how effective the settings are, since I dont encounter the problem myself.
if you recetly upgraded your device and experience problem you can do software repair using Xperia Companion
