Xperia Z3 Compact (No power & No battery LED light)
James84
Hi, i'm using xperia Z3 Compact for more than 2 yrs and now its suddenly not functioning (No power when im trying to switch on and no battery LED light when im trying to charge). I faced a battery (Battery Drain) issue when the software was still in Lollipop and after updating the software it was solve. Now i faced again a much worst than Lollipop (THE MARSHMALLOW) i think i upgraded my xperia Z3 Compact into a "TIME BOMB" that suddenly disfunctioning and it was only 2 months since i upgraded into MARSHMALLOW. I did all the tricks that has been posted at different site +button +power or pc companion but it does not give a function or response. Please be so kind to help me solved the problem. Thank you in advance...
profile.country.PH.title
MarlonUk1
if you already did all the solutions found here in the forum, then the only way to go is to have your phone checked at your local service center Local support
2 REPLIES 2
MarlonUk1
MarlonUk1
I got one more possible solution, how about using flashtool? http://developer.sonymobile.com/services/flash-tool/
