Water penetration problem
Omer77
Merhaba cihazımıza su gecirmez biliyordum bie sebepten dolayı suya temas etti bir süre sonra ses sorunu yasadım düzeldi ancak kameranın merceği buharlastı. Bu cihaz suya ve toza karsı sertifikalı diye beyan ettiniz simdi ne yapmalıyım
Hello, I knew that my device did not get water bie came into contact with the water for a while, but after a while the sound problem was corrected, but the camera's lens was vaporized. You have declared that this device is certified against water and tobacco, so what should I do now?
Translated with Google Translate
@Omer77
I'm sorry to hear that but you should contact your Local support and request a vacuum test.
