Water and humidity inside Z1 (still need more suggestions)
giorgos42
DSC_0044.JPGI put my Z1 under running water and after that I realized that there was humidity inside my phone (I could see it under my screen). All port covers were closed. Luckily, most of it dried up, but still some dots of humidity remain under the screen. Also, they haven't dried up a bit within 10 hours. What can I do? Please note that this happened after Sony removed the battery cover in order to replace the battery. Thanks in advance.
10 REPLIES 10
@giorgos42
Keep the phone away from direct sunlight and heat
