Volume up/down "beep" sound
martinmrmus
Hi. Am I only one encounter with there's no "beep" sound while voluming volume up/down? It just shows volume slider, but no sound is notified.
13 REPLIES 13
profile.country.RO.title
_alexdon_
I can reproduce that, my guess is that it doesn't make any sound for the first screenshot as it might be done by accident if the power button is pressed. But let me try to find out more about this too.
alexdon
_alexdon_
The screenshot sound will be fixed in an upcoming update. @mrnino@almirsahbaz@em2evol@downfall
alexdon
DC-RSA
@alexdon Who says this is intentional? I don’t believe that! It’s a bug. One is supposed to hear a conformation beep to be able to adjust the volume to the desired level for current surroundings. To give one an indication of where the volume is at and if it is sufficient or not. I used it a lot to establish the ideal volume. Sony must fix this, I don't want to guess how load I set my volume!
@downfall Actually the beep volume does increase/decrease as you adjust the volume button which helps one to find the right volume for a specific scenario. Very useful indeed.
Xevious
I agree, I think the volume adjust beep should be back. Why did they decide to take it out in Marshmallow? It is a really useful quality-of-life feature in my opinon..
