I have problem with USB (MTP) connection between phone and PC Companion.
The Phone is not detected at all when connected using USB cable.
I have tried the suggestions in the FAQ and some of the points given in this forum.
Restart PC, phone, reinstall PC companion, check for updates, use different USB ports, cables tested PC USB ports.
What else?
Could anyone help? Thanks in advance
Make sure you are not using a USB 3.0 port and if that is not the problem, open Device Manager on your computer to reinstall the driver for your device while your device is connected with your PC via a USB cable.
Microsoft Windows Vista and 7 users
To open Device manager on your computer
Click on the Start button.
In the Search box, type device manager, and then press enter.
Microsoft Windows 8 users
Click the Desktop Tile to open the Desktop.
Click >> at the bottom right of the taskbar.
Select Control Panel from the Menu.
Select Device Manager from the list of control panel items.
Note: If you do not see the screen with the Device Manager option, click the View by drop-down menu and select Small icons.
Microsoft Windows XP and 2000 users
On the desktop, right-click on My Computer and click Properties.
In the System Properties window, click the Hardware tab.
In the Hardware, tab click the Device Manager button.
To reinstall the drivers for your device
Scroll down to the Universal Serial Bus controllers (USB section) of the Device Manager window.
Look for an MTP Device: Media Device, Unknown Device or any other reference to your phone. Click on this entry and choose "Uninstall" whilst leaving the device connected.
Wait a few minutes, and the computer will reinstall the drivers for the device.
Now, the phone is accessible via Computer/My Computer on your computer.
Have you tried to connect your phone to any other PC ?
Solution 01
Try to plug in with different USB cable with different PC.
Solution 02
Earlier I came across this problem but, I did a factory reset.
Solution 02
Restart your PC. plug in your USB into PC and phone, after that unlock your phone slide lock, password or patternt. already if you are having SPCC then skip the step on your phone. wait untill your PC detects your phone.
Solution 03
Restart your PC and phone.
Go to control panel in your PC add device and search for possble USB plugged in deivces.
Open your SPCC and add your device.
Solution 04
If all this fails repair your phone with SUS this software will guide you how to repair
if this helps give me kudos
Sam,
Thank you for you tips.
It worked.
I do have the same problem. my phone wont connect to my pc. And i have read all the possible sulotions, and i tried going to the Device Manager and when my phone is connected it says that "This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)"
can someone help me.? what does it mean??
@markz888 - All you need to do is follow the steps above to uninstall the device then reconnect and it should auto install the drivers again.
Ok, in this case choose the manual install option and point it to this file once you have downloaded it:
http://developer.sonymobile.com/downloads/drivers/xperia-z2-driver/
