I factory reset my Z3 Compact and put it to ultra stamina mode for the night, and when I woke up it was hot and went from 66% to 4% with the night. Please help!
Thanks,
Kevin
did you check what was causing the drain? settings>battery. try to take a screenshot and post it here.
also if it keeps happening for a few days, try to software repair using Xperia Companion
@nolramlb wrote:did you check what was causing the drain? settings>battery. try to take a screenshot and post it here.
Can't find the thing you were talking about.
Unlock the phone > pull down the notification bar > settings > battery > tap on the graph > take screenshots of the graph and the list
Here you go.
Is this enough?
Brightness was all the way down and everything was off.
I Haven't been charging my phone til 100% in the day but always put it to charge for the night. And I added a picture of my battery usage.
