Ringtone volume setting grayed out
Ikomz
I have a Z3 Compact with Android 5.1.1. The problem is that I cannot change the volume of the ringtone. I don't have any other sound issues. As you can see from the screenshot, the ringtone volume setting is grayed out. Any idea of what could be wrong?
14 REPLIES 14
rowyourboat
So if I am erasing all internal memory, how do protect all the documents and files I want to keep.
In the second paragraph, how do your directions apply to what I am doing? Am I meant to be turning phone off and taking the SIM card out before starting PC companion?
rowyourboat
Sony PC companion file won't open as well
profile.country.RO.title
_alexdon_
Just start the repair process, all the steps are given there. Why PCC won't open?
alexdon
sanwi
I had thé same problem, restoring the factory settings worked but I lost most of my data... (not the photos though). But it happened several times (this is the fourth), is there was another way that does not include resetting the phone?
El-Cid
This was the solution for me as well:
"My phone was on do not disturb, when I cancelled that the slider moved again... Hope it helps somebody"
locate the "do not disturb" setting and disable it.
