Problem with Xperia Z1
DevilCTA
Hello, my Xperia Z1 dont turno o, and id o charge it, there are a red light
Emir1
Hero
Hi @DevilCTA, I am very sorry to hear about that. Slightly_frowning_Face
Could you try removing any SIM- and SD card which may be mounted and see if that helps? Here's a photo of how you may remove the SIM card, and here's one for the SD card.
If it still does not start, could you try forcing a shutdown of the device and then try charging it for at least 2 hours and then see if it boots? In order to force a shutdown, press and hold the power- and the volume up button simultaneously until the device vibrates 3 times.
Let me know how it went! Slightly_smiling_Face
