i had some issue about the power button. it does not wake up the phone when i press it but the power key is pyhsicaly normal and in good condition. i had update my xperia z to android 4.4.4.. i need to connect to the usb power supply to wake the phone.. when i at the outdoor i cannot use the phone bcoz it does not wake up,. i had use some way to solve the problem. i had restart, press the volume up and power key.. please help me:smileyworried:
Try performing a system repair as this will often fix issues after an upgrade - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
