My phone does not detect devices using an OTG cable
9911
My xperia z3 compact. Is not supported the otg cable. How to support (enable)??? Plz help me
profile.country.RO.title
_alexdon_
@9911 Follow @Emir's advice and restart the device.
alexdon
22 REPLIES 22
_alexdon_
If you are running 6.0.1, you need to detect usb device from quick settings in order to find OTG.
alexdon
9911
O dont have this on the settings
9911
I need to root my phone?
_alexdon_
@9911 Edit your quick settings by pressing the small pencil and look through all the options, it should be there.
EDIT: The option is not there, you will only find it on capless USB devices.
alexdon
Emir1
Hero
Hey @9911!
As an alternative to what @alexdon wrote, you could also try connecting the OTG adapter to your device and then restart it, that should force an active connection. Slightly_smiling_Face
What accessory are you trying to connect to your device using the OTG adapter?
Keep us updated! Slightly_smiling_Face
9911
@alexdon I'm sure we do not have
9911
@Emir. I do to connect my dualshock 3.. On my version is 6.0.1.. Is not readind anything.. And my usb 8g. Is not reading ( open it)
_alexdon_
alexdon
Emir1
Hero
@9911 were you able to resolve it? I can see that you marked a solution. Slightly_smiling_Face
Let me know!
