mxtp problem
Sickem
mxtp problem
Reinicie mi celular y cuando lo encendí se puso el modo "protegido" y cuando meto mi cuenta para autenticar lo dice que hay error en el nombre de usuario o contraseña, mi cuenta esta bien solo que siempre dice que hay error. Ayuda por favor...
Restart my cell phone and when I turned it on it turned on the "protected" mode and when I put my account to authenticate it says there is an error in the username or password, my account is fine only that it always says there is an error. Please help...
-GT
moienmh1371
hi
i've been this problem too. tell me what is your android version? when i've flash my xperia from android 7 to 5 this is happen. for this you must flash your xperia to android 6 or higher and when done go to setting > security> protection xperia > and deactive it and when its done flash to android 5 if you want it
