How to fix sony xperia z: Won't turn on but led light glows blue when plugged to pc
Finnick
Also, when I plug it to the charger, the screen repeatedly vibrates then starts to turn on but shuts down again (with red led light). How do I fix this?
4 REPLIES 4
That seems more if a hardware issue, but try this
Connect your phone to a wall charger, press and hold power and volume up for 10 seconds, let it charge for 2-3 hours
John-BR
Hi @Finnick
Welcome to the community.
Have you tried the options on this page?
http://support.sonymobile.com/global-en/xperiaz/faq/I-cannot-power-on-my-device/
AmirSherlock
dude thanks it happened to me just now and it worked! thanks!!!
Izzy64
I kept doing the press volume up and power on , it took about 5 mins but it went back on
