FM Radio has sound out only when phone screen is turned off
Ottotriin
FM Radio has sound out only when phone screen is turned off. Same for speakers or headphones.
Tags (1)
18 REPLIES 18
Vick-1
I turn off the voice recognition Google Now, and now I work the radio
GadgetFrancois
Thanks Ottotriin! You're a genius.
In case anyone needs the instructions to turn off the setting again, Android 5 this is where I did it:
Google Now > Settings > Voice > "OK Google" detection.
All kudos to you. It was driving me nuts Slightly_smiling_Face
vishu405
I RESOLVED!
I had turned on "Ok Google" and configured it listen "From any screen". Looks like Google try then listen all the time and blocks FM Radio output to headphones and also to speakers😀
xtra
Kudos to who show how to fix this...it's not a bug but function to ease disabled using "Google Now."
If you still want to use Google Now just switch off screen then 📻 will working just fine.
profile.country.BE.title
Fireblader
When the "OK Google" detection is enable on any screen, the FM radio app does not output any sound. Everything else in the FM radio app works, e.g. tuning, but no sound.
After disabling the "OK Google" detection, the FM radio works again.
However this "OK Google" setting has a bug of it's own. Every once and a while in enables itself automatically.
Pretty annoying.
profile.country.ES.title
eXPerience83
But the problem only appears on Radio FM. So Sony should update their app to work with OK Google.
ramdg
just turn off  ___ from any screen____ option in "OK GooGL" ..... and it will start working !!!!!!
anishyadav
Unistall Google and play fm and install
anishyadav
Google,settings, voice,voice detection,off
