Got my hands on a Z3 again and yeah I do notice the difference with ClearAudio+
Any thoughs or comments @Rickard
The equalizer can also work for 3:rd party apps but not all apps may use it. As you mentioned, some apps have their own equalizer for example.
I tried it here and i'm afraid YouTube doesn't seem to use it. To check that the equalizer is available for 3:rd party apps, try another app like Spotify or https://play.google.com/store/apps/details?id=com.jrtstudio.music
I will forward it as feedback but i suspect how it works now is how it's supposed to work.
