Hi @Onlykaka,
Welcome to the community.
The function isn't available in all devices, and I don't have a Z2 here to test it with so I cannot confirm, but to enable or disable the Doubletap to sleep function you need to tap and hold an area of the homescreen, or pinch in with 2 fingers, and select the Home settings option (on the bottom right). In here, you will find "Double-tap to sleep".
Hi @Onlykaka,
