I have an Xperia Z2 updated with android 4.4.4. When I try to take pictures at night I just get purple photos. This started just a few weeks ago out of nowhere. Let me say that the lens is not dirty nor blocked by anything. I don't have a case. I have just restored the phone today with Sony PC Companion and still the same issue. Any solutions for this...?
Still it's just a light isn't it? When we take picture on the street of xenon head light they appear blue in photos but shoudn't affect lens itself, it might be a broken film or proccessing unit. when taking a photo of a laser on the wall, the rest of the photo shoudn't be affected with red blur, you know what I mean, it's just the light as I see, the lens are clean.
Hope sony service will repair it, good luck!
One post in the correct place is enough - No need to spam the forum
Hi Team,
I was great fan of Sony smart phones, my previous phone was Xperia Z1 I had to change it to Z2. i have a seniors issue with low light picture snap in auto or manual mode I need to get rid of it.....
My current using version is 4.4.4
Build number 23.0.1.A.167
Below image is the example pic which I had to take in low light.....kindly give me a solution for this. I have received lollipop update but i am feeling worry about issue after upgrade !!
sony xperia Z2 in low light
Thanks,
Vinay Kumar.
Do you have a case on your Z2?
I get something similar (but not as bad) when using the flash when my case is fitted to the phone. The flash refects off the edge of the cut-out on the case back in to the lens causing loss of contrast.
If you have a case, try taking a photo with it off. If you don't have a case - make sure your fingers are well away from the flash when taking photos.
Yes I have back cover for my phone, okay I will try to take the snap tonight with out back cover.
Do I need to enable night mode or any other changes to take snaps in low light ?? can I go for updating new firmwork I got 23.1.A.0.726.
Let me know..
Don't use flash if you use nightmode or check this guide
http://talk.sonymobile.com/t5/FAQ/Capture-better-photos-in-low-light-conditions/m-p/395397#U395397
but do report back
LOL !! when my friends took my phone by seeing this low light pic actullay snap by Xperia Z2.
Do I need to think this is normal or do I need to make any changes ???
I am really disappointed with the flagship of Sony Xperia Z2 using Camera and that to my phone is not supported with LTE.
When I was purchased the phone on that box its written as LTE supported, unfortunately when I absorbed that there is not LTE option available in my phone. from the Google the Indian supply D6502 is not supported... 😞
At least I am trying to update my Os to lollipop but worrying about issues after upgrading......
What should in do now ????
