After you install the update for my phone my phone charger Sureste reduce Cardio setting kullandıgım half. as it occurred this charging shortage. Endurance mode lift was so bad on the phones. We charge these phones feature an ideal situation in whether he preferred the new version we got picked up in the middle of this incident fully. I want her to get better before the one it. Don get back to the old mode or they may improve this condition.
My Z3 has suffered from the battery drain issue since upgrading to Marshmallow in June. The phone used last at least 24 hours between charges and never died after 12. I cleared the cache and did a factory reset but that didn't make much difference. I eventually did a Software Repair using the Xperia Companion desktop software. It can be downloaded here http://support.sonymobile.com/global-en/xperiaz3/ (scroll down to the bottom). Now the phone lasts well into the night and even with moderate use is only down to 40% after 18 hours use.
I have the same problem with the Xperia Z3 + Dual E6533 (6.0.1).
Typing a message on whatsapp for example, the battery falls 3% in 1 minute, downloaded GSAM application, and tested 100% to 10%, which has consumed is 10% apps, 60% screen, how can I fix this?
Already use with brightness minimum, I have tried resetting the PC Companion but solves nothing.
This BIG problem is not only on DUAL, it exists also on Z3 and Z5.
Heavy battery drain AND high CPU Heat.
and still no smartwatch screen unlock since Kitkat...
