Battery can't charge more than 20%
Premiumgotstami
Restart also can't,max 20% when battery charge
Emir1
Hero
Hi @Premiumgotstaminamod, I am very sorry to hear about that. Slightly_frowning_Face
Does it charge past 20% if you have the device turned off? Also, could you try calibrating the battery by charging it fully (to 20% in your case), and then use it normally until it completely discharges. Once it's done so and is turned off, press the OFF-button next to the SIM area and then charge it fully while it's turned off.
Let me know if that helps!
10 REPLIES 10
Emir1
Hero
Premiumgotstami
Still can't
Emir1
Hero
That sounds strange, but could you also try to perform a software repair using Xperia Companion in that case? Try that and let me know if it helps!
Rs6
Hi mine is doing exactly the same. I can't charge it above 20% which means I can't update the software to resolve the problem any ideas????
Emir1
Hero
Hi @Rs6, sorry to hear that. Slightly_frowning_Face
I know that it is recommended to have a well charged device for the software repair, but since you're not able to charge above 20% it is worth giving it a try without charging it. Could you try that using the instructions provided for a software repair using Xperia Companion and let me know how it went?
However, before software repairing please try calibrating the battery using the instructions that I provided here, it's a good starting point when experiencing such behaviour that you described. Slightly_smiling_Face
Rs6
Hi Kudo thanx for the info. I've tried to update with the companion and I've just pressed the button and it's still registering 20%. Have you any other ideas??? Kind regards Russ
Rs6
Sorry Emir thanx
Emir1
Hero
In that case I would recommend that you have your device sent to an authorized service center for examination @Rs6. Slightly_frowning_Face
For instructions on how to send it in, I recommend getting in touch with your Local support since they're well informed with your local service routines, warranty terms and consumer laws.
Rs6
Thank you I sent it on Saturday. Thanx again for your help Russ
