Im using Xperia XZ1 for 1 month more less
For a couple of weeks it works fine, and then when I was using it for playing a game (LineageII Revolution) it's getting hot and the battery drained so fast, and then I turned off and charged it until full, after that the problem starts until now
The phone is getting warm even though i dont use it, also its getting hot when I charge it, im using QC 3.0 and i also try to not use QC it is UCH20, but its still the same
The battery drains so fast as well, from 4 Or 5 hours for Screen on time, becomes not more than 4 hours 3,5hours more less
I already checked all my app which is running on the background but its useless, i change my phone setting its still the same
And I factory reset twice and it didnt work
I think the software is broken, and then I Software Repair from Xperia Companion through PC, but it didnt help
I checked my CPU with CPUZ, it should be Deepsleep when I dont use any app and it should be showing 0ghs or sleep status for the CPU Cores, but it shows 300ghz when i dont use any app, it cant sleep until 0ghz
I need help
Sorry for my bad english
Thanks in advance
Have you tried "optimise battery for gaming" in Xperia actions?
