連結藍牙時,無法完整聽完任何歌曲(任何有聲音輸出的都一樣),是能連上藍芽播放器,但是都會斷斷續續一直斷點的聲音輸出,不論是重開機、軟體重新下載、換連結別的喇叭……,測試多次結果都是會斷點聲音;另外臉書的相簿或是留言…任何有關文字的打字時,鍵盤都會無反應,也就是鍵盤的不論注音、英文、手寫…都會完全死當機無法輸入任何文字,就算有重開機、關掉所有背景作業程式、更新下載…都是無法在臉書上輸入文字,但在其餘app,都不至於那麼誇張的無反應,另外在螢幕的觸控上,也很容易無法快速反應點選,都必須用力或多次點觸螢幕才會有讀取手勢,都已經是購買SONY的超旗艦手機了,本身也是索粉的一路支持,但換來的只有旁人個個的慘痛購買後悔經驗,拍照片也沒有比別的優,軟體效益更是差,請問到底該怎麼辦?如何解決客戶的問題(XZP
If the Bluetooth link does not fully listen to any song (all the same there is no sound output), it is able to connect to the Bluetooth player but it would have been breaking the sound output either restarting, re-downloading software, sharing link ...... other speakers, test results are often breaking the sound, another book album with your face or leave a message ... about any text type, the keyboard will be no response, ie if the phonetic keyboard, English, handwriting ... will be completely dead when the device can not enter any text, even if there are heavy boots, stop all work program by the background to update download ... are unable to enter text in the face book, but in the rest of the application, they would not be so exaggerated no response, the other on the touch screen, and you may not click fast response, must be forced or more many touch screen gestures will be read, they bought the Sony super-phone handset, all the way to lean on the cable powder However, in exchange for the painful acquisition of regret by others, the pictures are no better than others, and the benefits the software is even worse. What to do? How to Solve Customer Problems (XZP
gt
