I have noticed recently that whenever my phone connect to the internet or disconnect from the internet it keeps doing a notification sound and I can't find how you turned it off any help
@Darryll81 wrote:I have noticed recently that whenever my phone connect to the internet or disconnect from the internet it keeps doing a notification sound and I can't find how you turned it off any help
Do u have Lifelog app running... Try turning it's notification off....
Yes it looks like your right. But can't see why when I can't find any WiFi connection notifications in the options but turned notifications off and the sound stopped. Thank you. 😁 👍
@Darryll81 wrote:Yes it looks like your right. But can't see why when I can't find any WiFi connection notifications in the options but turned notifications off and the sound stopped. Thank you. 😁 👍
😄 ya it took around a week to figure it out.. it was so annoying.. and tried digging lot of settings app related notification turning off until finally came to mind the Lifelog is the only guy watching the connectivity running 24 hrs in notification bar .. I turned it off and voila....
Glad it worked for u..
