Java problems
Bromle
Java problems
Hi
I have the Xperia XZs (G8231) and it had to be repaired due to defect headphone "hole".
After they repaired my phone they did a software upgrade/factory reset.
Android 8.0.0 now, and no newer updates awailable.
Now to my problem:
After I installed the apps I use links in different apps try to open in a small window, whereas before they would switch to and open in Chrome .
In Chrome I have Java enabled, and no problems, but those windows that opens when i press a link in my mail apps or messages app or other apps says that there is a problem and that I need to enable Java.
I've tried to uninstall/reinstall several apps but am at status quo.
Anyone got any ideas?
Tags (2)
0 REPLIES 0
