High battery drain
alexhdkn1
High battery drain
Hi everyone, how long your XZ1 C lasts? I can barely end a day with a single charge, most of the time being under wifi connection. I don't use social media, only Instagram, i have 3 mail accounts with hourly updates, and telegram and WhatsApp.
14 REPLIES 14
Damo_
@alexhdkn wrote:
My older G6 with Snapdragon 821 had a lower battery drain during night and it has a less efficient chip (14nm).
The G6 has a higher capacity battery so you're not comparing apples with apples. Regardless, 6 days standby is still more than respectful, that was my point.
alexhdkn1
I think I figured out what kills the battery, it's either Telegram o the mobile signal.
Tizer
Alexhdkn, you may be right about a poor mobile signal. I have a good 4G signal where I live and my overnight battery consumption is 2%.
I don't have Telegram and most of the Apps that I don't use everyday are Force Stopped until I need to use them. I don't have Stamina Mode or Data Saver enabled either.
I also have the June update (.205) and my battery consumption has not changed since installing it.
alexhdkn1
This is today, i've been using with Chrome, a bit of Instagram, Onefootball app and Telegram X client, and that's all
alexhdkn1
Now I have used this phone for 15 minutes listening to music with Spotify with the BT of my car with 3G in background and sent some messages con telegram and that's all.
