Finger print sensor is not working on wet or sweaty fingers on my xperia xz1
Same thing, terribly annoying
Hi @BIBINBMV, @Encorer;
That is how it is supposed to work, your finger must be dry because the fingerprint sensor must be clean and without any visible moisture for it to work correctly.
In order for it to work on XZ1, the fingers and the sensor should not only be clean, but sterile
