Hello, my phone Sony XZ charging socket broke inside, it's still possible to charge it, but when you connect cable doesn't feel that it fixed. As well visualy you can see that charging socket moved deeper when it was originally. I still have warranty covarage and looked thru SONY forums and this problem is common for this device, but my local warranty service told that it's mechanical damage and ask me to cover repair expenses. I would like to know what should be my steps to get warranty service which I suppose to get?
Search the forum and read what happened.
Maybe it will give you some arguments to ask for repair under warranty.
I have had problems with my charging socket tonight after my phone got sprayed with water straight into the charging socket.
As the phone is fully waterproof I have no idea why this would prevent the phone from charging when I have had it fully submerged previously. My phone was low on battery when his happened and so is now dead. But the charging light doesn't come on when I plug it in either.
Anyone got any guesses?
