xperia miro: display problem
gmani333
My xperia miro is having a display problem. Its screen(display) is ons and offs on its own. Pls help me to solve this problem.
6 REPLIES 6
Jake-SonyXperia
Champion
This may be due to a third party application, you may want to check all applications you have downloaded and see if they have Wake Screen options.
Let me know how this goes.
xtianfriborg13
I'll try it out. Slightly_smiling_Face
aki143
i have the same problem i just bought xperia miro ... annoying problem is that xperia miro screen keeps blinking even when i turn it into sleep mode... or just keep it locked it keeps blinking ... do you know what should i do to make it stop i changed themes and settings but nothing is working it keeps on annoyingly blinks every 2 seconds ...? even at charging it keeps on blinking every 2 seconds ... on off on offf... ?what shoulfd i do?
tbiswas
I am having one issue now after updating the system to 11.0.A.5.5
Sometimes red background is flashing behind the screen.
This is very annoying.
Can anybody help me on this?
Thanks and Regards,
Tanmoy
bangad_pavan5
i have also faced the same problem of blinking of red color around the corner of the screen...its very annoying...plz provide some solution to this problem
bangad_pavan5
i have also faced the same problem of blinking of red color around the corner of the screen...its very annoying...plz provide some solution to this problem...
