x10 mini pro: unable to take call with headset when using FM-radio?
If I use the built in FM-radio with the x10 mini pro headset, with the FM-radio turned on, the radio stops when a call comes in. The button to take the call doens't respond however. Is this normal  behavior? It does work with music.
Thanks for you help!
J
2 REPLIES 2
probably got do with the fact that the periphreal is used as the antenna, maybe try removing the jack.....?
interesting question though....does anyone know if the radio is taken from a true fm signal or does it hook up another source as that might explain why it limits the functionality on the cellular network.....?:smileymischief:
I'm not sure if I understand correctly, but I meant the button to take the call on the headset. So you can call using the headset, leaving the x10 min pro where it is (in my pocket mostly). Unplugging isn't what I want. I just want the headset to work properly. When listening to music on the x10 mini pro using the same headset, the headset does work how its supposed to work.
So to sum it up:
- Headset with FM-radio: unable to use the headset to take a call
- Headset with music player: able to use the headset to take a call
What's the difference?
J
