Wifi Problem
Wifi Problem
Hi...
I have sony ericson xperia 10 mini pro and I cant connect to my wifi at home. but i can at someone elses.
It just comes that it is disconnected even if the signal srenght is good and i can use the net with my ipod and my dads htc phone.
I have downloaded the wifi fixit but it still dosent help..
does anyone know what I can do.
Johan
Master
If it works on another Wi-Fi network but not on this one it sounds like you need to make some adjustments to the settings in the router.
But before you start checking your router settings you could just try to reboot both your phone and router to see if it helps.
