Wifi Problem .. plz help :( :(
Noran
my xperia SL has a problem with wifi .... when i find a network it can not connect or it says not in range even if i was so close to the router
3 REPLIES 3
Samuel1
Hero
Does this happen with all networks you are trying to connect to or just one?
Noran
i didnt try it with any other router . but also when i enter the password for the network it tells me that the network is saved but the lock sign still appears and it cant connect Slightly_frowning_Face
Samuel1
Hero
Well, to rule out if the problem is related to the router or the phone you should try to connect this phone to another network.
